Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon Feb 25, 2008 5:25 am
Not clear on what you want to do - are you wanting to remove individual leaves, or are you wanting to remove the entire spring pack?
Your truck is a 2wd, right?
To remove the packs, you need to get the frame on jackstands and the wheels off. Unbolt the 2 ubolts on each side securing the axle to the spring pack and use a floor jack to lift up the axle. Regular through bolts hold the spring to the hanger in front and the schackle in the rear.
I wouldn't remove an individual leaf, as your spring rate would end up way to soft and you'd bottom out on every little bump.
