quinner49er »
https://forums.nicoclub.com/quinner49er-u129626.html
Fri Jan 04, 2013 8:40 am
I have a 2008 M45X. It has both the LDW and Snow switches to which you are referring. Both of these were options, depending upon your model and accessories. According to my owner's manual, and as the others have described, the LDW default is to automatically turn itself back on when you restart the car. You can then turn it off or back on by pushing the switch. To switch from automatic to manual mode (default is OFF) push and hold the LDW switch for more than 4 seconds, when the LDW ON indicator light is off. You can then use the switch to turn it on or off, but the default will be OFF.
The Snow switch is on the console between the left seat heater/cooler switch and the rear sunshade switch. It works much like the Winter Mode switch on my wife's Volvo V70 AWD. I usually engage it on icy or snowy roads. It basically controls the engine output to avoid wheel spin. It is especially useful when pulling away from a stop on snowy/icy roads, but it definitely reduces your ability to accelerate quickly.
