Larz »
https://forums.nicoclub.com/larz-u216291.html
Mon May 11, 2015 9:03 pm
Check the FSM in the above post - it's under ("dash removal" or similar)to make sure, but I believe there are two screws at the bottom of the screen. I know you can get to the top of the screen and trim by un-snapping the center radio speaker grille (3 clips in the front and it slides forward i think). You might need to remove the black multi-switch (NAV, DISP, SETTINGS) ... and to remove that, you need to remove the small wood / aluminum trim that lays between the speedo cluster and the multi-switch. (not the long piece that runs in front of the passenger dash)
*** be VERY careful when un-clipping that speaker grille - it's flimsy and bends VERY easily! ****
They probably recommend that you start at the console and remove everything until you get up to the display scree, but when I wrapped my multi-switch in carbon fiber, I seem to remember seeing that the screen was accessible after I took off the wood trim and the multi-switch.
