Lazy starting rb25det
jayz706
Once the car is warmed up it starts ok, however when shes cold shes a B***CH to start.
Any ideas? maybe a the wrong or a bad MAF or something simple like that
JonPowell
Car: Cars, Music, My family
Temp sensor(2 wire)IAC valve inop/malfunctionAir regulator inop/malfunction
Temp & regulator are most probable.
Timing might be off also.
Could be a dirty MAF too, use electical cleaner to spray down the element inside, DONT USE BRAKE OR CARB CLEANER!
JonPowell
Could also be an air leak on your cracked runners???
jayz706
Different motor.
jayz706
where is the air regulator? Could it be the tps, what should it read across it
jayz706
Oh yeah, to make it start when its cold you must touch the throttle.
JonPowell
Air regulator is under the intake manifold....
Sounds like IAC or Air regulator, not TPS....sounds like it needs a little more air flow to even out the fuel its getting.
jayz706
JonPowell wrote:Air regulator is under the intake manifold....
Is there an adjustment on the air regulator? How should i adjust it
JonPowell
Air regulator is NOT adjustable, IAC is adjustable.
Air regulator works off temp
IAC works off a signal from the ECU. What is your idle RPM once the engine warms up? if it is correct then you dont want to adjust this.
Check this out also....
http://club240.com/forums/show...16091
Sounds like same problem, we are trying to trouble shoot over there also.
jayz706
T[QUOTE=JonPowell]Air regulator is NOT adjustable, IAC is adjustable.
Sounds like same problem, we are trying to trouble shoot over there also.[/QUOTEThanks Jon I will try this stuff.
jayz706
Looks like we wernt getting a good enough start signal, just for the heck of it we ran a jumper wire from the starter signal( straight from the ignition) to the ecu and it seems to be working great. The big test will be this morning after sitting all night.
JonPowell
Any luck?
jayz706
Yes its working perfect. Thanks for the help
eh?
I have a lazy starting RB25 also. I must crank 4-5 times before it idles. Because of that my starter died. So look out.
jayz706
mine starts as soon as turn the key now..
eh?
So it was the start signal? Ecu pin 45?
jayz706
Cant remember what pin number, but yes it was the start signal causing the car not to start properly.
