zachosz »
https://forums.nicoclub.com/zachosz-u2609.html
Thu Jun 26, 2003 11:04 am
Ok, here it goes:
You need:1) 6 male and 10 female connectors2) 20-30 ft 18 gauge wire3) 2 switches, any style you want but for me the best kind is a flip switch.
MAKE SURE YOU DISCONNECT YOUR BATTERY!!! You have to locate your headlight motor relay, on the passenger side right next to the coolant reservoir. You have to remove the relay labeled "H/L RET CONT". Then you would have to connect the wires like it's shown in the diagram below. NOTE: Don't make the 2, 3, 4 and 6 wires too long, 3-4 inches is enough, otherwhise you might have trouble closing the fuse box. 1 and 5 can be as long as you want them to be, depending on where you want to place your switches. You can place your relay upside down in the space next to the plug and close the lid. THAT"S IT!!!!!!
Now the tricky part: with the switches in the ON position, your headlights will operate as they normally do. In the OFF position, your headlights will come on BUT they won't come up. What you have to do is turn on your lights, then flip the switch ON/OFF quickly 2-3 times, or until you get the desired gap, personally i think 3 fingers looks the best.
Please note that I only have one switch in mine, it's connected to 5, 1 is not connected to the switch. That means that whenever I turn the lights off, my headlights reset themselves. I like it that way.
