Klits562 wrote:um is that your current 240 in your sig, the one you cut the brown wire on, if so your sir fail
#1...you actually wanted someone banned for doing a common mod and having an issue......sir..you fail!
#2. hay bro...did you check the fuse box and look for a blown fuse?...allso..if your turn signal harness is pinched where it comes throu the front bumper..it would crate some wierd running light and head light issues...hope this helps..good luck and dont listen to the guys post above..he still dosent get...that nicco is ment to help people..not hinder them...post back with what ya find.
