Lazy Eye Headlights Help
Including HI and CA
PsyckoDrifter
Car: 1993 Nissan 240SX SE
alrite guys...call me a noob but i heard theres a way to rewire your headlights so when you turn em on you have a preset lazy eye position...it had something to do wit hooking up the ground wire somewhere else...someone told me i can find it on these forums...any help is appreciated...thx a lot...
sideways in 916
Car: 91 240sx SE
well i dunno about all that but if you just pop off your headlight button (the one to just flip them up) and cut the brown wire then you can do it just fine. once you cut the brown wire push the button in and turn your headlights on. then turn your headlights off and just double click the headlight button until you get your desired position. the only downside of this is that you cant just flip your headlights up by using that button. you have to push the button in and then turn your lights on/off. really no big deal at all. works great.
onosqv
Car: '92 240sx Vert
First of all, this will prob get a better answer in the tech section of the forum...
Second of all, if you search, you will be able to get the gist of what you are doing.
There are 2 options:
Either you do something like the lazy eye for the "off" position but w/ the "on" wire, which you can find either by browsing through the FSM or I believe it's on here somewhere... that is not as reliable or consistent...
The other way is to do something like clearcorners - you change out the actual rod, will close in full close, open in sleepy eye.
The cheapest way is to always leave in sleepy eye (by cutting certain wires etc... you can find via search) etc except when you highbeam or something, where it pops it back up.
Many many ways to do this... this will take some searches, and lots of reading...
sideways in 916
Car: 91 240sx SE
just cut the brown wire. very simple...
Red coupe
Car: 92 Nissan 240sx Coupe
most of you guys didn't even read this post....he said he wants lazy eyes with lights on...brown wire trick doesn't do that. If you take the group away from the motor it wont work anymore...so a switch somewhere to disrupt the ground is probably what you read about. Search like brokeass said. try Lazy eyes, sleepy eyes...half closed....all that related stuff I guaranty you get your answerer if you work for it...
Return to “California Region”
