Meaux »
https://forums.nicoclub.com/meaux-u23660.html
Wed Jul 04, 2007 6:01 am
1994 Q45 86K 18" 350Z wheels, Avon 245/45Replaced O2 Sensors, Plenum, TB, KS last year... New Shocks and Steering Boots... I work on this thing myself...
I've allways had a lazy shift from 2-3 and now it's gettin on my nerves...
My plan is this... There is a GM Dealer in town that advertises the BG system... and I don't look forward to working on the A/T in the driveway... So, I'm gonna get a Filter and have them Flush/Change all the Fluid (Looks good BTW, no leaks). Do I need to ADD a BG Transmission Cleaner in a can for a few miles before I go the the Dealer?I bought a can of BG Conditioner awhile back when I wasn't thinking, and was gonna ADD this after the fluid change...
I'm also gonna go to 16" Wheels cause I'm getting wear on the inside of the driver's side front tire... With stock tires, no wear... Had an Alinment (Toe-In) and nothing works... Should have never went to 18's... Bad "Ride" for a Q... I did replace the upper links and T-Rod bushings a few months back...
I know a "Fluid Change" won't fix a broken Transmission, I'm just hoping for some improvement... Thinkin' about dumping this Barge... But, I like the big lug...
Thanks...
