Layla got new wheels (sort of)
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I got tired of the chipped cracked and yellow clear coat on teh machined lips of Layla's wheels. I wanted polished lips. I started with my drill and a paint remover head (it actually took 2).
Then I sanded the clear coat off
Then I wet-sanded it with 240 grit, 400 grit, then 800 grit sandpaper
Then I stepped up to 2000 grit
Finally, I used my power ball and some Mother's metal polish
What do y'all think?
Modified by Jeff Williams at 6:15 PM 1/8/2006
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
golden!!!!!!!!!!!!!!!!!!!!!!!!!! Looks really cool...
and much better.
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
Sure wish I could do that with my pie pans...if I could get mine to look like nchopp's pie pans I would be happy. His at least look like brushed metal instead of plastic *** like mine.
DrewQ45
Car: 1990 Infiniti Q45
Looks real nice there Jeff. Did you do all 4 wheels already? Must have taken you a minute huh? Would be nice if there was some tough glaze you could spray back over it and not have it look crappy in the process.
...Drew...
Rex
Car: None
Looks good Jeff, any before/after pics of them on the car?
And how long did it take? Any risk/damage to the tires?
ceningolmo
Can you do the old rainX treatment? Its not a permanent solution, but it might help keep them from getting tarnished... maybe.
nchopp
Looking nice!
Ross, yeah, I got lucky with these. They're in damn good shape. Not that I care too much about the wheels at this point - she's going in to the mechanic tomorrow. I pray to God it's nothing more than $300...
squeefoo
1994 Nissan Maxima SE
1999 Infiniti I30
2003 Nissan Maxima Titanium
2006 Nissan Xterra Off Road
2012 Infiniti G37x S
Those look very nice, lotsa "Armstrong" in 'em now... You can make them chemically clean and shoot them with some nice, expensive polyurethane clear (spraybomb) which will last for awhile and hold down the oxides.
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
looking good!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Very nicely done!
heywier427
Car: 91 Q45
yep polyeurethane is the best stuff to use
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
I did 2 Saturday, and 2 Sunday. Took about 4 hours each day. I also cleaned up the calipers, rotors, struts, suspension, and inner fender wells while I was in there. My camera batteries were dead, and I didn't think about the before and after shots, until I was on the last wheel. I didn't clean up the car, so I did not do an after shot. It is dramatic. The wheels shine like chrome at night, which is the best time for wheels, in my opinion.
Pie pans would be much easier, since they are relatively flat. The recessed surfaces are/could be painted.
As far as clear coat, I will NEVER clear coat my wheels again. It just doesn't last, reduces the shine (unless you get a professional job), and is a PAIN to get off. I will just keep a heavy doat of wax on them, and use soap to clean them, instead of the wheel cleaner (by the way, wheel cleaner is murder on zinc plating).
I used the soft paint remover brush. I tried not to get the tires, and had to be careful about the painted centers. I used thick packing tape to protect the paint.
I bought 2 colors for the centers. A silver like the factory paint, and a graphite, which I though would look great, but Evie said the silver would look better on the silver car.
BOY, are my arms tired! It has been a long time since I block and sanded a car. I forgot about the arm ache. I am not as young as I used to be.
Thanks for all the compliments, that is why I posted. It always feels better when you put a lot of work into something, to get compliments on your work.
Peterofdevon
Car: 94T 70K, miss mannors, 96 Black on Black 72K, raw sex
Good job.
I did my OEM 93 wheels three years ago. It took two hours per wheel. The clear coat lasted six months...oxidation set in again and by year two they looked like crap.
I pretended they looked fine.
Peter
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
great job Jeff - looks sweet
Falkdesigns
Car: 1998 Q45t ~ EXE
Damn that looks good!
5seryan
Car: 1995 Q45t R.I.P.
Jeff looks great. BTW i noticed you have some Fuzions on there. I just got some HRi's and for the money you really cant beat them. 280 out the door. What are your thoughts on them? BTW the strut bar in TITTES. Thanks again.
yodawill2000
Car: 94 Infiniti J30
Theres some super strong clear coat that motorcycle builders use on there chrome engine fins ..Gotta look that one up ..Supposed to be dang near bullet proof .
Jeff Williams
2000 Infiniti I30t
2004 Infiniti M45
5seryan wrote:Jeff looks great. BTW i noticed you have some Fuzions on there. I just got some HRi's and for the money you really cant beat them. 280 out the door. What are your thoughts on them? BTW the strut bar in TITTES. Thanks again.
I personally HATE them! Well, not hate, but they are noisy, and are wearing terribly on the inside.They have feathered rather badly. I have had the toe and caster/camber adjusted as much as the Q will allow. It could be the upper links, since I have about 60K on them. I have not had good luck with the directional tires on the Q at all. I think I will go back to Sumitomo HTR+ next.
