launch....
Turb0wned
what do you guys lanch your 240 at, when u go to the track or whenever u race i wanna go to the track soon and i wanna get the best launch possible
IneedMoney
Car: car
you got to find that out for yourself. your car, tires, track surface is all diff. and can change your launch... try around 2000-3000 rpm
Nismo_Freak
Car: 89 Nissan 240SX
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
5400 and dump the clutch...
no jk
I launch around 3500 feathering the clutch out.
Altiman94
Car: 1989 Nissan 240SX
I got the best times iwth dumping it at 5k. Tried slipping, everything. Track was soo sticky that day I had no traction problems, but yet im stock too
89S13SILVIA
Car: CARS
i slip it from 4500 to 3500 and dump depending on how the track feels test it a little play around with tire pressures i set mine at 16 then went back up to 20 or so and gained .2 tenths i think them being that low slowed me down but after i raised them i still hooked up almost the same
