Look in the other post on the FSTB. There are a few picture of it on various cars. The difference is, the modifications required to make it fit, basically. The hats seem to be a little thicker steel, but won't really make a difference, because the angle of force applied to the metal.Heath wrote:Okay I know I already have one on my car, but its cold outside and I'm to lazy to go look... Can you post a pic of the older version too Jeff for comparison???
Quick answer: It braces the upper mounting points of the struts. The brace keeps the towers from flexing individually. It transfers the force from one tower to the other, stiffening the body flex.bravetex wrote:What is the purpose of the bar?
And a good set of tires. you wont feel it at all if all your car is doing is understeering..... Rear sway bar is key.Jeff Williams wrote:
I would suggest replacing all the struts, tension rods, sway bar bushings, upper links, and strut mounts before adding the FSTB.
Amen! First things first. I would add inspecting steering rack mounts also. And like Wes says, if you have funky tires, what's the point?Jeff Williams wrote:I would suggest replacing all the struts, tension rods, sway bar bushings, upper links, and strut mounts before adding the FSTB.
AMEN! This quickens the initial steering response so much the rear can't follow as fast.....kinda scary to me. Enough so that I have the active rear sway bar on the way to cor rect this.elwesso wrote:
That's great, Jesda!Jesda wrote:This bar is fantastic! For once, my Q isn't understeering off of highway onramps. My fondness for the 5-series is finally waning.
