No... I'm just a broke a$$ college student living off scholarship money
My local mechanic just gave up on warranting a seal for the Accord and said go to Honda. Also, I took full advantage of the local Honda dealer when they hit the Accord with a new car, and they were at fault. Got a free paint job, warranty work, and loaner for like 10 days. Typically I only use dealers for oil changes and tire rotations because regular maintenance. If something looks doable for me with the tools I have in my garage, I go straight to DIY and the stuff done. And this weekend, I have to self-diagnose the HVAC issue for the Honda.amc49 wrote: ↑Tue Aug 21, 2018 11:20 pmThe induction service likely means simply flushing the intake with seafoam or the like. Waste of money. Take it from someone who has never paid for car repair ever and for over 45 years now. The only place in the intake stream at all that ever needs any cleaning is at the throttle body aircrack and possibly the PCV valve itself, both are close tolerance metering devices and need to be kept clean. Maybe EGR passages on some types. I forgot the MAF, that needs to be kept clean as well. All other cleaning there is pretty much free money for dealer and does nothing to the car to run better, longer at all.
I have never changed a PCV valve in my entire life, you simply drop the original one into a container of strong solvent (I use acetone) to let it dissolve any deposits, blow it out and reuse it like a new one.
I never change tires ever except in pairs only and I never rotate tires ever either, pretty much all FWD vehicles add a wear issue that RWD never did and nobody ever says a thing about it, but they sure will sell you those 4 tires at once when they wear all wonky as the rotation actually makes that issue WORSE. I get virtually the rated mileage on all tires used unless they simply go bad from suncracking here in the Texas heat. I even quit balancing them about 3-4 years ago and STILL the cars don't shake whatsoever and drive like a new one at all times. I align all my front ends as well and using a measuring tape, an angle finder and string, and how I used to align 200+ mph race cars.
Most of you won't agree with that but I assure you my reality can be yours if you simply look at things the way they ARE rather than how all the 'in-the-box' thinking says it is. The dealers and other repair shops are NOT your friends other than at bill paying time and even the entire industry is tilted against you if you really want to know it. I have spent my life bursting that bubble thousands of times to my personal benefit.
