rb25drag »
https://forums.nicoclub.com/rb25drag-u76935.html
Wed Apr 23, 2008 4:53 am
This is what I have searched and found.
3. From the brown KA plug under the dash above the ECU, connect the Orange wire (#34 Start Switch @ ECU) to the RB white plug Grey/Red wire (AF09 Start Switch).· 4a. From the KA ECU plug, connect Red wire (101 ECCS Relay) to RB white plug Red wire (AF04 Ign Relay).· 4b. From KA ECU plug, connect Black/Red wire (#36 Ign Switch Fuse) to RB white plug Black/Red wire (AF36 Ign Relay). Get this B/R wire from the KA wiring harness.
The wire I had to replace Im having problems with is the Red/Black wire. So my question is Im assuming the Red/Black #36 IGN switch fuse wire is the one I need to replace. But Im not sure were exactly its running from. Or what power it needs.
