tyrannix »
https://forums.nicoclub.com/tyrannix-u27595.html
Wed Apr 12, 2006 7:21 am
wednesday apr26 >
for real, L/R is pissing me off
ok, on the FSM, the FICD valve is B, L/Gmy sensor plug is L/R , L/G
this L/R HAS to be a ground?
so,... seriously.. L/R sometimes == ground? or what (and what compressor is that listed next to the FICD on the L/G ? )
CJ
>>edit>> the harness has been cut apart, wires fixed, now i just need to match up a few colors with what they do/where they go
or i was sure... until i looked at the 'corrected' FSM, the plugs are different... it makes alot more sense now
the L/R now clearly goes dash plug->main harness->coil packs, but the dash is unnecessary, so it will just go main>coil packs (done, FTW)
and the BR goes AAC solenoid, O2 sensor,Pres reg solenoid, main harnessbut the BR was cut away on my harness, doesnt make sense, but thats how i will wire it, (AAC solenoid, O2,main) and see if i fry anything
[/edit]
original post >>>>
ok, im almost done with the wiring harness stuff
first question, is there any possible reason why i cant shorten the wires to the dropping resistor (and stick it near the wiper motor)
then what exactly is A? (on the harness i got, its looped and capped, on another, it is capped, but the hose is only on one side, then plugged?(couldnt find the wire colors in the FSM wiring diagram)
B looks like it needs to do something
and all the stuff in C can be deleted?
Modified by tyrannix at 8:25 AM 4/26/2006
Modified by tyrannix at 1:37 PM 4/26/2006
Modified by tyrannix at 9:47 PM 4/26/2006
Modified by tyrannix at 9:48 PM 4/26/2006
