Carl H wrote:you have an auto trans car, hence the plugs being diffrent.just cut off the 3 wire plug and connect that black and yellow wire to that 2 wire black and yellow.use a continuity tester to check and find out which of those yellow/blue (really yellow/green on one...) is the prong for the oil pressure switch, wire that one into the other wire on the 2 wire plug and then shrinkwrap/tape off the remaining wire. sooooo that being said the black/yellow wire is the starter trigger and the yellow/green is the oil pressure switch.done and done.
Ah, perfect!! That's the answer I was looking for.. I figured it had to be something to do with the Auto transmission I pulled....
Thanks for all the help!!
Btw, are there a lot of Rb owners in Charlotte? I'm visiting friends and family in late August...
