last minute question...
95Zenki
Car: 1995 Nissan 240sx
I have an S14 and I am doing the 4 to 5 lug hub swap. I have the hub for the front and the hub for the back with the bearing. I also have the rotors for the 5 lug hubs. Do I need anything else for the swap? Also, is there any particular lub I need to use when I put the new hubs on? Thanks for you help in advance.
hannibal
Car: Red Line to Glenmont
Sounds like your set. The S14 is much easier than the S13. Just use your old calipers with the new 5 lug rotors and you should be good to go.
95Zenki wrote:I have an S14 and I am doing the 4 to 5 lug hub swap. I have the hub for the front and the hub for the back with the bearing. I also have the rotors for the 5 lug hubs. Do I need anything else for the swap? Also, is there any particular lub I need to use when I put the new hubs on? Thanks for you help in advance.
But I'm not sure what you're asking here...
95Zenki
I was just basically asking if there is any lubrication I should use when I put the new 5 lug hubs on the car. If not it is cool but I wanted to make sure I covered all my bases.
