last minute question...
95Zenki
Car: 1995 Nissan 240sx
I have an S14 and I am doing the 4 to 5 lug hub swap. I have the hub for the front and the hub for the back with the bearing. I also have the rotors for the 5 lug hubs. Do I need anything else for the swap? Also, is there any particular lub I need to use when I put the new hubs on? Thanks for you help in advance.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
95Zenki wrote: Also, is there any particular lub I need to use when I put the new hubs on? Thanks for you help in advance.
There is nothing else to do; you're all set to go.
I'm confused with the second part of your posting where you say 'any particular hub on the new hubs'. Maybe you're referring to wheels.
If you're considering Z32 brakes, then some OEM wheels may not clear the caliper assembly.
180fan
Car: 89 fastback
mmm, don't forget the new 5 lug wheels lol
95Zenki
Thank you so much for your help! Yea, I am working on getting wheels. I am thinking something along the lines of 350z wheels or g35 wheels.
