Last few wires on my rb20.. please help - trouble understanding guide..
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
I am following a 13 step guide, I have 1 through 9 done..
Name of the guide: S13 KA to RB20 Swap
which is for SOHC ...
Anyway...
Step 10 says: Now there will be a plug with 2 wires in it on the ka chassis harness, one being white and the other being black/yellow. Find the black/white wire on the other rb plug and connect the two..
Ok, so I find the 8 wire plug that it is talking about.. I find the male and female (in step 3 it says cut the female end up about 6 inches of both plugs 6 and 8 which are the same size on the rb harness )
Only problem, I am using the KA lower harness, not with the rb lower...
So, the female end was on the rb20det lower harness connected to the fusebox, but the wires hanging down.. Male plug was on the lower harness
Step 10 is saying connect both the white and the black/yellow wires together with the black/white one on the rb plug????? That takes it to the lower harness, ..... Maybe i will follow it to where it goes and then hook the 2 wires????????????? up to where it goes, or just the black/yellow wire???
Next question...Step 11: Coming out of the fuse box there will be a plug that contains a small white/red wire, take that and connect it to the white/red wire coming from the rb motor harness by the alternator...
On this I am guessing it is from the main harness?? But, I do not know where exactly...
On the lower, on the plug that has 8 wires in it there is a white/red wire, but again, where to.. maybe ill follow that too :-)
That seems to be it, I think...
2 or 3 wires left, heh..
Any help is appreciated, Josh
