Musclehead »
https://forums.nicoclub.com/musclehead-u72797.html
Wed Aug 13, 2014 10:01 am
It's a 95 with 127,000 miles on it, and had been running rough, and stalling. It's missing big time. Did a few of the basic checks I learned here, MAF, oil in cap, etc. Got it to the shop, they said codes 0340 cam position sensor and 0325 knock sensor and erratic spark, but plugs were good. They also found both CV boots split and leaking and it needs new serpentine belt. They also said sway bar links and bushings need replacing.They recommended a new distributor ($1000, they said it should be OEM) and another $800 to replace both axle shafts, and belt. I said I wasn't going to put that kind of money into the car (The valve cover gasket leaks, and large crack in windshield) figured I'd part it out. Now I kind of think I should have gotten more miles than this, should I put in an aftermarket distributor? Is it hard? I'll have to check out he Chiltons book from the library (They know me well). I can probably figure out the belt, not sure about the axles. Part of me wants to get rid of it, sick of always repairing it, but hate to give up. What if the distributor doesn't fix it. It died 6x on the way home, so it's here but I have to make a decision and decide how much I really want to put into it.
