docsmile71 »
https://forums.nicoclub.com/docsmile71-u7208.html
Fri Oct 15, 2004 12:51 pm
The post with the service record is here
http://www.nissaninfiniticlub....31389 Since then, the car has had the following service. 1. Snow tires (pirelli wintersport 210 215/65HR15) ordered 12/2/032. Rear brake pads ordered from Scottsdale infiniti 2/9/04. Installed locally at Macmillans Auto. 3. 7/14/03 Mileage 55,742 LOF, Transmission flush including drain and flush all fluid out of transmission, torque converter, and cooling system using a cleaning solution. Refill system. Checked engine for any stored codes. None found.4. 1/5/04 Mileage 63,047: 60K service (minus the transmission service which was done 7/14/03) including LOF, Balance wheels, Flush cooling system, Replace spark plugs, and gen vehicle inspection5. 8/30/04 Mileage 72, 871: Replaced front trans seal and trans pan gasket. Resealed freeze plug left rear cylinder head. That's it. I have all receipts in a file. Oh, and I also just replaced the drivers side power window regulator.
