ok guys so the shell is completely redone and all ready for the motor...iv cleaned every part i can reach and orderd everthing i thought i was going to need except the bearings... this is where i need some help.iv done the math for getting the codes for an oem replacement but im using the original crank ( checked runout ). i found these ,,,
http://cgi.ebay.com/ebaymotors...ories
And although the price is some what unbelievable, their ACL and i just need bearings asap. i've read that with after market bearing companies the codes on the block and crank need not apply?
Also my second problem is my pistons. i orderd a new oem replacement from west coast nissian for my 4th cylinder that blew, and the 3 i will be using over ( with new rings ) arent exactly the same as the one i recieved in the mail ?!...This is the new one and you can see the large hole thats IS on both sides in the corner. it still has the two small oil holes so its either to kill wheight or another lube possibility idk ?...This is one of the old ones and it obviously doesnt have the holes...
Am i going to be able to use this combo of pistons or do i need to figure out whats up before i put them in and they wheigh different, or lube different ? thanks for any help guys im really dyin to get this thing running. ill def get some pics up as soon as it starts progressing a little better!!
