Postby
wcbjr »
https://forums.nicoclub.com/wcbjr-u6827.htmlSat Aug 30, 2003 6:09 am
Stock RB20DET motor. What's the largest turbo that will fit, larger than I could ever need on a stock motor? T3/T04E 50 trim is what I am thinking about.
Postby
cyris3d »
https://forums.nicoclub.com/cyris3d-u3944.htmlSat Aug 30, 2003 6:09 am
i test fitted a t3/t4 on my rb25.. the front housing rubbed a lil bit on the manifold.. soo we are making an adapater box to move the turbo out a bit too add space to add a external waste gate...
Postby
93semax »
https://forums.nicoclub.com/93semax-u4196.htmlSat Aug 30, 2003 6:09 am
cyris3d wrote:i test fitted a t3/t4 on my rb25.. the front housing rubbed a lil bit on the manifold.. soo we are making an adapater box to move the turbo out a bit too add space to add a external waste gate...
How about adding a T3 exhaust flange between the turbo and the manifold?
Postby
DCIracer »
https://forums.nicoclub.com/dciracer-u9708.htmlSat Aug 30, 2003 6:09 am
If you add a T3 spacer inbetween the turbo and manifold, your ordinary T3/T4 hybrid turbo will fit - now you just need to find longer bolts to do that and two gaskets.
