He's a new guy just looking for a little help, and he asked nicely to boot. Why not just answer his question instead of being a d!ck?alexf20c wrote:search harder
funny, you didn't answer his question either.Buzzman wrote:He's a new guy just looking for a little help, and he asked nicely to boot. Why not just answer his question instead of being a d!ck?
Sadly, no. Any decent amount of lift is going to cost you $500+, whether it's a spring lift or custom subframe drop. You could get metal strut spacers in the $140-$180 range but they only net you about an inch of lift. Also you could get rubber coil spacers pretty cheap ($10-$20 per), but again, only about an inch lift.I haven't heard of anyone being able to retrofit OEM springs from a different make/model vehicle (unless it was in combo with a custom SFD).IronMaiden wrote:I'd like to raise the front about 2" to level it out. Are there any inexpensive ways to do it without spending $350 on a 2" lift kit? Are there any other OEM springs that can be retrofitted?
I guess I'll give the spacers a try or see if I can find some new front coils. I'm not trying to lift the rig much, but more or less just level it out.KyooX4 wrote:Sadly, no. Any decent amount of lift is going to cost you $500+, whether it's a spring lift or custom subframe drop. You could get metal strut spacers in the $140-$180 range but they only net you about an inch of lift. Also you could get rubber coil spacers pretty cheap ($10-$20 per), but again, only about an inch lift.I haven't heard of anyone being able to retrofit OEM springs from a different make/model vehicle (unless it was in combo with a custom SFD).
I personally have one-inch rubber coil spacers on all four corners (although technically they're only to be used on the rear springs). Not much difference, but it didn't cost much.
Tjdriggs wrote:
Just remember, wide tires, less bite for traction as you lose pounds per square inch where the tire contacts the ground.
Not wrong. You're both saying the same thing, just in a different way.(BTW, ever wonder why those really old cars, like model T's, were so good in mud and snow? Those big skinny tires).alexf20c wrote:wrong. the narrower the tire, the higher the psi where the tire contacts the ground.
