Largest tire can fit on stock 3.5se on stock 17s
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
Jcampoli
Car: 02 altima 3.5se
Got my 02 3.5se few months ago for a steal and I have brand new 235/65/17s laying around I'm asking if theyll fit or do I need to run spacers or what it's my daily when I dont use my truck and would love to run these tires also looking if there are any ways to lift it as I bottom out often in my area and everything I own I usually find away to lift it. Thanks in advanced
macgiver
if no reliable answers here for a while -1) get advice from more than one good tire dealer (know the actual rim's inside width ) ,2) OR just mount ONE and see how it actually fits a Fr & Rr position, If they look real close when "eyeballed" unmounted along side of Fr & Rr fenders. Tirerack.com also has specs for min/max recomended rim widths per specific tires/Brands of their large inventories , yours may be listed? Also they have "alternate" & "plus size" calculator too.
SMC-RJB
Car: Altima 2006 S
Not sure how close the chassis in an '02 is to the '06, so take this advice carefully. I am using Nissan Maxima 18 by 7½ alloy, six spoke rims with Michelin Pilot Sport A/S 3+ tires (P245R18 by 18") on our 2006 Altima. The tires fit and do not rub. This combination was selected to make the speedometer more accurate (GPS indicates 101 km/hr when the speedometer says 100 km/hr or about 1% over. As the tires wear the values will be even closer.)
You and I differ in direction, I would lower the Altima. And our roads up here are not any better than down there. For winter we use 16 inch five spoke Altima rims with Michelin X-Ice tire (P225/60R16"). Both sets of tires, summer and winter, are almost exactly the same overall diameter and both are recommended highly.
Robert
SMC-RJB
Car: Altima 2006 S
No response from the original post. The tire size calculator at (https://tiresize.com/calculator/ ) shows, based on the tires we have on our 2006 Altima, that either 245/50R17 (26.6") or 225/55R17 (26.7") should fit.
Return to “3rd Generation Altima Sedan (2002-2006)”
