Some of you might have seen my post about upgrading to 20" wheels. What I didn't tell you is that since that time I'm having hard time to find a good place to balance my tires. Bigger wheels mean more weight and thus more chances that imperfect balance will show itself. Basically, the issue I'm having is that as the speed exceeds 60-65 mph, wheels start vibrating. From what I gather from research and talking to technicians, I would need high speed balancing machine that would be more precise. Supposedly, a regular machine would not work. The shop that installed my wheels is a reputable full service shop but they don't do enough tire installations to justify an expansive balancing machine. I've tried another local shop, which was by the way recommended by tirerack.com. I described them the issue, told them that I need high speed balancing and they swore to me that they have the best equipment in the world. They were descent enough not to charge me and let me drive a few days to see if the issue is fixed. However, the vibration is still there.
Anyway, I call shops, start mumbling about high speed balancing and hear the same thing - we've got very good equipment and no one complains, come over and we'll take a look at it. Obviously, I'm reluctant to spend time and money just to check whether a shop's machine is good enough in my case.
Frustrated...
Another thing I stumbled upon on the web... Supposedly, a some tire manufacturers mark heaviest spot on their tire (no tire is perfect). Installers should first find a heaviest spot on the wheel (again, no wheel is perfect) and then match the heaviest spot on the wheel with the heaviest spot on the tire. Then balancing is easier and doesn't require as much weight thingies to be adjusted. Supposedly, not all installers do it.
