larger tires
johnsavas
Car: 2001 nissan pathfinder
i am trying to figure out what is the largest size tire that will fit on my 2001 pathfinder without any lifting? also if purchasing wheel spacers will help i can do that, thanks for the help
Ubel Feuer
Car: 2003 Nissan Pathfinder
Someone will be along with tire sizes.
As for the spacers please don't use them. They are dangerous.
esy
Car: 2002 Nissan Pathfinder SE 4x4
search is your friend. i know it's over at NPORA, but i'm certain that a search here on nico would've been able to yield very similar results.
http://npora.ipbhost.com/index.php?showforum=67
johnsavas
thanks for the replies, and why are wheel spacers dangerous?
also do you think 30" tires would fit without any rubbing?
esy
the only time that i've seen or heard about spacers being dangerous is if they're improperly used. other than that, they're perfectly fine.
check the link because it still doesn't sound like you've been looking through the link and all the pinned topics. ;)
sicwitit
Car: part fabricator
I've installed 265/70/16 Nitto Terra graplers on my stock bodied, non lifted R50 pathy. I did how ever have to trim the stock front mud flaps, and trip the front bumper, and relocate the fender liner mounts located on the front bumper. The wheels I used are 16x8J et +5
I think this size is probably the biggest all terrain tire you can go and still have your truck function without serious modifications to the fenders, bumpers, or removing the over fenders. here is a pic of the rear at almost full flex, the tire is just barely rubbing the over fender.
johnsavas
Thanks man this helps alot, you think you could send more pics of the wheels and tires on your pathy?
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
My tires are not any taller than stock but they are Alot Wider. 275/55/17.
shelby500krz
Car: 2001 Nissan Pathfinder LE 2WD
Just search the site....
suspension-lifts-101-t491011.html
Ubel Feuer
What I'm interested in is a beefier tire than 255/65R 16 that requires no alteration to the vehicle.
esy
Ubel Feuer wrote:What I'm interested in is a beefier tire than 255/65R 16 that requires no alteration to the vehicle.
again,
whatchugot12
Car: 1997 Nissan Pathfinder XE 2wd
Bad link.....is there another one available???
