Victor »
https://forums.nicoclub.com/victor-u94029.html
Sat May 03, 2008 6:41 pm
Article in today's LA Times says pimping your car with bigger rims and wider low profile tires decreases gas mileage. Says 20% of your fuel goes to overcoming rolling resistance from tires. The bigger and wider the tire, the more rolling resistance. Article says also to not use rain tires if you drive on mostly dry roads. Also, worn tires get better gas mileage than new tires since they have less tread on them, plus are smaller diameter. The larger the rim size, the worse the performance because of rotational inertia being much higher for a 17 or 20 inch rim than a 15 or 16 inch. The lighter the wheel the better, like the forged rims on a J30T being much better for performance than heavier cast rims. There can be as much as a 10% difference in gas mileage between using best and worst tire for your car. Generally one should stick with the tires that the car manufacturer supplied when new. Large tires are also less aerodynamic than smaller tires, adding extra air resistance to the rolling resistance. Article says the tire industry is fighting a proposed law to make them list the rolling resistance of their tires.
