Larger Oil Filter for the SR20 and KA24
Silvia007
Car: 93 Nissan 240SX SE Fastback
Ok, people do this at your own risk, and I'm not sure if anyone knew about this but I work at a Quick Lube and have plenty of time to go through oil filters and cross reference them.
I'm using fram numbers because they are available anywhere.
SR20DET = PH4386KA24DE = PH3682
Those are the orginal oil filter sizes. One filter that is slightly larger then the one for the KA and is a whole lot larger then the one for the SR is the
PH2870A
Which is for this following vehicle.
2000 Volkswagen Passat1.8L Fuel Injected DOHC AEB Turbo
I included the car's make model and engine info so you can find the oil filter of your choice, just look up that car for whatever brand of filter you need. My friends SR20DET is running on Mobil oil filter using the one for the Passat has not had any leaks what so ever and oil filter is still tight. He has a Blacktop S13 SR by the way, I'm sure this oil filter will work for all other SR20's and KA24's. Looking through the forums, I've seen quite a few questions about oil filters so I decided to put this up to see if anyone is interested. Some reasons why you would want a larger filter is that it has more capacity, meaning it can hold more dirt before it starts using the bypass valve which will just circulate dirty oil back into the engine, another is less restriction in the circulation of the oil which in turns provides more oil for lubrication.
caliracer240
Car: cars and chicks
bigger filter means a slight more oil capacity in the engine too. Interesting.
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
This applies to the SOHC KA24E too???
Poatree
Car: MTB racing, driving, etc
sounds like an interesting upgrade
Silvia007
niznos wrote:This applies to the SOHC KA24E too???
Yep, it should fit the SOHC too, seems to be of the same oil filter as the DOHC.
ItsTooSlow
Car: 1989 240sx
Bringin this thread back alive. I came across this and Im interested to see if anyone ended up trying this and what your outcome was
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
How exactly does the filter work for both SR's and KA's when the KA and SR filter are not the same.
The SR uses respective year Sentra filters (USDM SR20DE's).
Cone Junky
Car: S13 fastback
BMW e46 328i
Interesting...I work for a VW/Audi shop and have dozens of these in stock. I'll probably verify fitment at my next oil change. Bosch, Mahle, and Mann are all quality German filters and that application should be able to add another .5qts to oil capacity.
But then again, I'll probably be running an oil cooler on my next motor, so I may just set up a remote filter, increasing my options and capacity even more.
onosqv
Car: '92 240sx Vert
ddgsxr504 wrote:How exactly does the filter work for both SR's and KA's when the KA and SR filter are not the same.
Thread & gasket size are the same. I believe the SR guys can't use a KA filter out of the box because it hits something near the oil filter block location. KA guys can use the sr filter if they want w/o issue.
I currently run a greddy sr oil filter relocator kit on my KA - I can run sr/ka (as well as rb) oil filter w/o issue.
ddgsxr504
Really, I was told by Greddy that their relocation kit only worked with the AE86 filter. Interesting.
onosqv
Car: '92 240sx Vert
Really, don't have a super detailed pic, but see the blue oem ka filter sitting on the passenger side? that's connected to the sr oil filter relocation kit - I may have posted a better picture a long time ago when this was brought up originally.
autox615
Car: 1995 Nissan 240sx
interesting, I'd like to know if I can put a bigger filter on my motor, someone try it out now!
