G4nismo wrote:
omg are you serious? that post was certainly wrong, i don't even wanna know where the hell you saw that from. keep ur stock housing. You want the MAF to be larger or at least the same size as your TB, with the airway between at a constant size, usually the same as the MAF housing or slightly smaller.bigger housing would prob slow the velocity of the air through the maf sensor and then speed it up again as its going into the engine.
Its true about the gains, it was NMexMax but thats a 3.5 motor....
I did this with the Land Rover Maf housing I forget the model numbers, I felt the gain and tuned the engine back out myself, have yet to get a dyno. Probably won't ever do so with this motor.
I'm going to a 90mm Maf housing with the new motor, now what g4 said about the air flow being slower over the sensor is true, thats why I am using an EU because you can program in the change in size of the MAF housing
