ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Mon Jul 05, 2004 1:36 pm
No, you don't need larger injectors for an N/A application. That is, unless you have a completely built N/A engine, then you might be on the verge of needing new injectors. Other than that, forced induction is the only reason you will need bigger injectors on a KA. As far as making more power in the 4800-6000 rpm range, a KA is no different than any other engine. If you want to stay N/A, intake, header, exhaust, cams, etc. However, the KA responds best to forced induction, I don't think I've ever seen any KA make more than about 175 hp to the wheels without it. Good luck.
