Large Mileage Loss
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
86 720
Car: 1986 720 4cyl Standard Cab
Went from 28 MPG to just over 18MPG. Truck isn't running bad, idles fine, and there isn't a fuel leak that I can smell.
Thinking it may be vacuum. Any ideas of what it might be or which vacuume hose?
Standard carb, could just need a re-build or new...
fastboatman29212
Car: left this forum. Sold my truck.
If you were getting 28 mpg, then I need to rebuild my carb, cause I'm only getting 22mpg, and I thought that was about average. I sure would like to drive it more if it got better gas mileage. Great, you just gave me another project to do. Oh well. It should be fun.
lambohaha
Car: `85 720 2wd std cab
Mine gets in the neighborhood of about 25ish or so. So yep, you got to get busy and make another one of your fine "How To`s" for us lol.
PEZi
Odd.... I never got more than 24 with the stock carb! I suppose that may have something to do with altitude, though.
drumaniac3000
Car: 1986 720 4x4
I'm seeing high teens with mostly highway driving with my bone stock z24.
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
I had been seeing 25+, but lately I've dropped to around 22.5 consistently regardless of how aggressively I drive. Then again, my secondary is all screwed up right now.
Z22 2wd truck.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
sounds like you're dumping gas. Are your plugs fouled?
woodbutcher5691
Car: 85 720 2wd 5sp.
3- 280zx's
Could be the summer blend gas is not as good as winter blend affecting your M.P.G.s. This subject has popped up before on other forums around this time of year. I don't know if there is any truth to it though. I'm seeing +/- 20 M.P.G.s, seems like mine have dropped a little too.
fastboatman29212
We should all be aware that factory mpg ratings for these trucks were calculated before ethanol enriched (diluted??? :confused: ) fuel existed. All vehicles get better mpg with no ethanol. Anyone have the 2WD and 4WD mpg factory ratings for these trucks? (They were always predicted and never actually got what the rating said anyway, but it would be interesting to know.)
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Have you hooked up a vac gauge to it yet? What's it reading and what's the needle doing?
86 720
Guess I should quit bitchin with my mileage huh?
I did notice it happened after I changed the vac lines, but it's been well over a month now since I did that. I went back over all the lines, and they are all ok.
Haven't done the vac gauge. I'll need to go buy one, where do I hook it to?
synack7350
i'm avg'ing 25mpg with the 32/36. less for highway but I'm running the 4speed AT.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Do a general tune up and see what happens. Your milage should improve regardless of the blend of fuel.
Return to “Datsun 720”
