Large exhaust size pros and cons?
Trippermatix
Well ive been looking at the Apexi GT-Spec exhaust and it sais that it uses 3.74 inch tubing. When i search around I dont seem to find many people with exhausts that are that big. This leads me to wonder if that big of tubing has more cons than pros and if I should not get it. (it does say that its used to create maximium horsepower but on certain aplications.) Can anyone help me out?
onosqv
Car: '92 240sx Vert
Hi, welcome to the forums.
First off, try searching for exhaust size. This is mostly discussing 3 vs 2.5 piping, but same idea here but w/ more dramatic difference.
Unless you are going turbo, there is absolutely no reason to have 3.74" piping. A 3.74" tip is much different than piping - I'm too lazy to check the GT Spec specs.
In a nutshell: bigger piping = better upper end / smaller piping = better lower end, with some give & take & details depending on other mods, situation etc.
Trippermatix
Oooh, alright. I guess thats all I needed to know, thanks.
babowc
Car: 240sx
whoa! 3.74 piping cat back?!that is humongous..
