poshatch »
https://forums.nicoclub.com/poshatch-u145419.html
Thu Sep 15, 2011 4:26 pm
ok so i went to a skid pad event a few weeks ago, i let somebody slide my car who wasnt used to it and he ripped my e brake crazy hard (it didnt have much travel and great bite before that day)
after that day the rear calipers were locking up randomly and staying locked a couple of times and i lubed the mechanical part of the calipers it stopped doing that
but now the rears dont seem to bite as much as they used too and the e brake feels like its hitting a certain point on the pull and not twisting the piston in anymore so its hitting a clamping limit. Also, i feel brake pressure slowly start to slip away as i put my foot on the pedal and it just goes down and down
but im not leaking any fluid from any caliper whatsoever, the car has no leaks at all. the car stops fine though just at a stop it does that
i pumped the pedal to build pressure and the usual 5 click pull of the e brake usually is enough to keep the car from rolling back, and it was fine then it started slowly creeping back so i had to pull it up an additional 2 clicks so pressure seems to not be holding
i never opened the lines so i doubt there is air in there
does anybody know what it could be??????? appreciate any help thanks everybody
