Lame question...
mmdb
to pull the engine in/out:
when hookin' up the engine to a engine crane where do you put the hooks? or is the basic idea just to wrap 'em under and over the engine? Also, will the transmission need to be taken off before installing and reinstalling the engine?
Holisticbeatz
Removing the transmission from the block, then dropping in the motor, then reinstalling the transmission once the engine is in from underneath the car. Sounds like a lot of extra work, just put the motor on a jack and slide that bad boy in with the transmission. Jack it up, line up mounts and bolt it in.
mmdb
alrighty sounds good
mmdb
thanx
