Lag on a FMIC
rudee023
Car: '03 Infiniti Q45
I recently installed my Blitz LM and have noticed alot more lag than I thought I would. Is this just because of the big core and 3" piping? I am running the stock T25.
ride4lame
it makes sense, there is more space to be pressurized. If it is extreme, make sure to check for leaks in the piping:)
Dori Dori
Car: Cars of course
Yes, all the piping and big core are difficult for the little t25 to pressurize. Lucky for you, the blitz lm core has very little pressure drop. ;)
If it's extreme, you might want to triple check for leaks and make sure you're BOV is adjusted properly.
I mean, the difference shouldn't be night and day...just a little bit of added lag. I know with a WRX FMIC kit, it needs 2x the piping of a s13 and the difference should be much more extreme (goes from basically no piping and a tiny core to tons of piping and a mega core). I've felt a WRX before and after and it wasn't that bad.
dj_lennon_franz
Car: 1992 240sx
with a T25 u will lose bottom end quite a bit...but ull gain ALOT in top end...same thing happened on mine with my HYBRID FMIC...damn thing is HUGE...but in the long run its soo worth it =)
RobDET
Car: Cars
Never had one without a FMIC but my lag is not really bad at all. It spools as quick as my old GSX with the stock sidemount.
Bryson
Car: 93 240sx Hatchback /w Sr20
hey DJ with your hybrid intercooler what hotpipe did you use?? I'm using the hybrid piping but the enjuku hotpipe and they don't meet up for crap. I finally go my Sr running but it bogs so bad I don't wana try to drive it yet I'm pretty sure tis a vacuum leak.
dj_lennon_franz
Car: 1992 240sx
i just made one...used a DSM BOV and had a flange made for it...but yah...its just made outta 2.25 inch piping...not that pretty but it works
Bryson
ya my problem is the enjukue hotpipe is 2.25... the hybrid lower pipe is 2 and there is like a 2" gap and 45 degree angle between them!! I mean really wtf!!! its like this!
dj_lennon_franz
Car: 1992 240sx
just get a really long peice of 2 inch vacuum hose like u get with the FMIC setup...thats what i had to do for the cold pipe...damn thing was WAY too short...so i just used a REALLY long peice of super industrial 3 inch vacuum hose ;)
Bryson
hah thanks, I gave that a try but it didn't work :( the problem is my angle on the two pipes but I think I found a temporary if not permanent solution. I bought a 2" diameter radiator hose today that has a 45 degree bend in it. The 2" pipe fits perfectly and the 2.25 inch hotpipe can be worked into fitting. Haven't tried it yet but I think its gonna work. That leaves needing the BOV welded on and the o2 sensor hooked up and I think thats it.
LSB_11
Car: cars, motorcycles, sports, flying,
what hotpipe did you buy from enjuku, i just purchased the hot and hks ssqv kit from them and have a hybrid FMIC.
240SXer
Car: 1995 240sx SE (2jz powered)
What size is your hybrid intercooler? This is mine.. Yours the same?
Bryson
yep mine is that same one, the big one. the Enjuku pipe i bought is the sort of \_ shaped one.... what kind of connector are you guys using there?? can u just take a pic of it for me? thanks.
