WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Tue May 10, 2005 9:23 am
Bad turbo, smaller runner exhaust manifold, old as hell cat, stock cams...Definitly will cause a problem at higher revs, he's gaining speed he just doesn't have the pull. The lack of pull would be caused by a lack in torque, which drops off like a lead weight at anything over 6400 with stock parts. The motor can't breath, you'll never see high rpm pulls without opening up your exhaust system and getting rid of that tiny T3.
Swap in a T3/TO4E and you'll have enough volume to flow 450WHP with no lag problems. Get rid of the cat...install a new one or use a test pipe. And have a set of cams made up at Integral, they quoted me $350 for a set of regrinds. Increase the lift and add about 8-10* of duration and you'll be able to pull all the way to 8000.
WD
