i've been doin this an awful lot lately, so ill give a few a shot.
GBSilviaS15 wrote:How am I supposed to get power to my labtop? Power inverter - depending on how many watts my labtop needs correct?
yeah an inverter should do just fine, just get one thats a little bigger than your draw. you could also see if your laptop manufacturer makes a cig lighter to laptop adapter, so you dont have to bother with the dc->ac->dc stuff.
GBSilviaS15 wrote:And would I have to keep turning on and off my labtop when I'm turning off the car, so it doesn't drain all my battery power?
just set it to hibernate within 5 minutes of non-use in battery mode. you can run the inverter thru a switched relay and it'll be on only when the ign is on.
GBSilviaS15 wrote:Oh and one last one, where can I find good quality speakers/subs to connect to my labtop that I can wire around and put in place of my car speakers/subs?
any good quality speakers and subs for laptops are usually ac and fairly hefty. youll have better luck running the audio output into your head unit aux channel if you have one.
