l28et.... broke something help please!
A home for 1983–1989 300ZX owners!
o_alcha3
so i went to change my coolent temperature sensor on my l28et. at first i couldn't find it. then i saw this unti that looks kinda like it(at least the clip was the right fit). i proceeded to try to take it off and it snapped. it is not made to be removed b/c there is no threads. oops.
1. what is the piece called that i broke the sensor off of?2. wtf does it do? (its got this spring loaded port with a sensor inside)3. is it the same on an n/a l28e?3. where is the coolent temp sensor?
came from here
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the broken piece is your FICV, nto a big deal it only helps for cold starts, as for the temp sensor, are you looking for the temp sender for the gauge? thats located on the bottom of the thermostat housing, got one green wire coming out of it, if you're looking for the one for the ecu then it is either on the botom of the thermostat housing but it has a plug that looks like an injector plug, if nto there then it's in the passanger side fo the cylinder head between the spark plugs for #5 and #6
o_alcha3
is it the same on the n/a
o_alcha3
o_alcha3 wrote:is it the same on the n/a
i went to the yard just incase anyone cares the n/a is diff but can be used with a little fabrication. thanks man
evildky
06 Nissan 350Z GT
I wasn't sure of they were the same but they work the same, it lets extra air in when cold for fast idle, as the temp rises ti closes, nto needed just makes for easier cold starts
cpt jack
Car: Datsun 280zx
hahahhahaha i broke my cold start valve on my last z and i never needed it except for the turbo cars theres a trick where you can keep it on and it dumps more fuel which means higher boost for someone
Return to “300ZX (Z31) Forum”
