L28ET almost overheating every time I drive it
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
o_alcha3
so i have a 240Z with an l28et. the motor is pretty much stock just intake and exhaust. it used to go 3/4 of the way to hot on the temp sensor when i was pushing on it alot. one time it got to the H when i was really beating on it on the highway.
since then every time i drove it it get about 5/6 of the way to H but never more. And it bubbles into the overflow after i turn the car off. and now it happens with just normal driving after about 8 minutes. but it will idle forever and not get past half.
i did a leak down test at about 60psi and detecting nothing as far as a bad HG or warped head. there is no burning of coolant and nothing leaking. I also took out the thermostat, just to get rid of that variable. and it didn't help.
any suggestions........please?
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Maybe you got a bad thermostat? Perhaps the water pump is giving up on you? Is there enough coolant in the car?
o_alcha3
no thermostat, water pump is pumping water from what i see in the radiator cap, and there is full coolent grrrrr
im thinking maybe the radaitor or the coolent passage lines are all grimy? idk?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
if it idles without overheating ans you're overheating on the highway it's almost definitely the radiator, might be flowing just not enough to get all the heat out
o_alcha3
i think ur right. i cleaned the radiator and so far no overheating but it is much colder out and i only drove it for 10 minutes
Dozer
Car: 1979 280zx
Check the tension on your surpinteen belt. And look for hoses with kinks
evildky
06 Nissan 350Z GT
Dozer wrote:Check the tension on your surpinteen belt.
lol, does anything but domestic's use serpentine belts?
Return to “Datsun Z Forum”
