I think an L28 is a great install because no one else is doing it. I am in the process of swaping one into my 1991 M30.
I read the other posts and I dont know why people think that L28 engines dont make power. The L28 Turbo that I have in my 1973 240Z was dynoed at 600BHP @ the flywheel. and the NA that I built for the M30 was dynoed @ 425BHP. I think that that is more than enough for my cruiser. I guess the engines that people say only make 200-300BHP are very mild builds, or simply carb and header add on engines with minimal internal modification, and no ignition upgrades.
Most people that build L28's just slap some carbs and a header on it, and usually don't even spend the extra money to have the carbs properly jetted and the proper size venturi installed for their application. Hell, an properly setup new set of webers will run you about $2000+ and between 400-600.00 for a good intake manifold. Most of the guys that I see at the track, and Datsun meets dont want to spent $13000.00 on an engine when they are not using the car for pro racing with a purse if you win. The difference between building an older L28 to make good power is you are not going to do it buying parts off the rack like everyone seems to do now days on the newer engines. There are many cam grinds off the shelf that are available, but if you want real power they are not the ones you need, Those cams are the ( simple to tune Cams) for guys that dont really do alot of their own work, so these are available so that the common Layman can install it on an average head, slap some off the shelf webers or modified SU carbs and roll!, and simple flat top pistons wont due either.When I built my NA, I spent almost $3200.00 just on the head!
This is an N42 Head, Full port and Polish. 555L 302Dur 106* 2.02SST Intake Valves, and 1.50 Exhaust valves machined and stuffed into the head!
The Cam was ground off of a Billit stock, not a regrind! Titanium retainers, Custom Manley Racing springs.
This engine Redlines @ 8250RPM
Makes power from 4000-8100RPM
12:1Comp Ratio
Carillo Rods,
Ross Custom Domed Pistons with valve reliefs.
The photo was taken with 44mm Brand New Mikunis, but I made 105 more horse power by using 45mm Webers with a Cannon manifold.
The header in the picture is a Nissan Motorsport Race header with 1.75 Primaries, but I have had to make my own custom header to fit in the car and was supprised to have gained 35 hp over the race header.
The distributor was only for the photo. The ignition system used is the Electramotive tech 1 system. A distributor would have spark float at the RPM range that my engine runs at.
