evildky wrote:I'm not a fan of the stock injection system found on the L28's, the L28ET system is marginally better but still not worth the drama, if I were you I'd find a set of round top SU's and convert to electronic ignition and forget fuel injection
Sounds too easy. Don't I already have round top SUs?
1. Late '69 production date up to the '71 models had a "bottle" or "bell" top piston chamber that was secured to the main body unit with 4 screws. Both front and rear carbs used identical rebuild parts. These carbs did not have water warm-up circulation chambers in the rear base and hence, used a square, 4 hole carb to manifold spacer/vibration dampener. There have been some reports of modest external visual differences in the carbs of these years, mostly in the lower hardware, but essentially they are all the same. These units are most often used to replace the troublesome '73 240Z & '74 260Z "flat top" Hitachi SU's when they go bad.
2. '72 carbs were almost identical in looks, but differed in several refined areas. The "bell" tops were secured with 3 screws rather than 4 and the rebuild parts differ between the front and rear carbs, primarily in the inlet jet assemblies. The '72 units also had their base casting altered to accommodate 2 warm water re-circulation inlet passages to facilitate quicker warm ups from cold starts and for other subtle technical improvements. These 2 inlet passages match up to a unique intake manifold designed with matching water holes that must be bolted up to each other using a proper manifold spacer/vibration dampener part with corresponding holes in order for the warm-up feature to function.
Converted to EI in '76 or '77. The manual choke is a pain and I don't want to break another handle. How about a set of triple Webers? Once installed a single Weber on a '76 Datsun PU and it made a HUGE difference.
Part of me hates to put a non-smogged car back on the road.
Thanks!
