L20B Cylinder Heads
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
onesixteenth
Car: Datsun 720, 620
Just found out my 620 has a cracked cylinder head (wasn't running anyways). I've been doing some research on a replacement head and found out there's quite a few.
A87, U67, W58, closed chamber, open chamber... anyone want to give me a good direction to head? Point me towards more information or even just opinion...
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
onesixteenth wrote:Just found out my 620 has a cracked cylinder head (wasn't running anyways). I've been doing some research on a replacement head and found out there's quite a few.
My Choice #
1= A87 closed chamber/ square exhaust ports- better compression and larger valves
2= W58 closed chamber/ Round exhaust ports- ditto ^
3= A87 open/ square exhaust ports
4= U67 (they are all open)/ square exhaust port- larger ports and valves
5= W58 open/ round exhaust ports.
onesixteenth
Thanks Phleb!
I also found this site (you guys probably know it already) that was pretty helpful in explaining all the differences:
http://www.olddatsuns.com/html/tech/head_ID_2.htm
pastric
Car: 1979 Datsun "King Cab" Pickup
I have the head with the steel liners in the exhaust ports. Except that one port (#1 exhaust) doesn't have a liner in it. Is that a problem? Is that normal? Anybody know where I can get one? Is there a special tool or technique for installing them?
Papi Chulo
Car: 72' Datsun 510
It's missing a liner?
They are a pain to get out. I don't think you would need to install a new one, because I doubt you could.
Do you have a pic?
ravera
Car: 1971 Datsun 240Z
those steel liners are actually cast into the cylinder head. I'm not sure how well the head would run, since the exhaust on #1 would be flowing substantially different than the other three.
NL320what
Car: '63 Datsun NL320 4x4
'04 GMC Yukon
'13 Chrysler 200 Touring
The A87 head is one of the best. NISMO catalog sells new peanut chamber heads for the L engines. But a U67 is hard to find in the states. You will see alot of W58 heads, and then the A87 ones after that.
NL320what
'04 GMC Yukon
You will not be able to install a new one in there. The head halfs has the liners installed before they were asssembled. I had a W58 head on my L20B. It take about an hour each to take them out. Installed a 280deg Comp cam and it ran really well with a Weber DGAS 38 carb and Offy intake.
If you cant take the other ones out, you should get another head on there cause the flow will be disturbed and robbing power and efficiency from you.
pastric wrote:I have the head with the steel liners in the exhaust ports. Except that one port (#1 exhaust) doesn't have a liner in it. Is that a problem? Is that normal? Anybody know where I can get one? Is there a special tool or technique for installing them?
Return to “Datsun Chat”
