L18 OR L20 ?
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
jakearmstrong
Car: 1969 datsun 510 2 door
WHAT IS A BETTER MOTER , I WAS GOING TO DO A SR20DET BUT IT IS TO MUCH MONEY. PLASE HELP
Mr1der
stock for stock, the 18 is rated at an extra 5 hp, but it also lacks a little torque due to smaller displacement.
how much power are you looking for?
jakearmstrong
i dont know i alway had v8 so i like hp how muck can you get out of the 18 or 20 if i put duals on the 18 would that help the torque
ehop
Car: 71' datsun 510 4 door
i have a L20 and transmission i could sell
Mig
Car: 1978 280Z, 1979 810 2dr, 1964 L320 Pickup, 2006 Chevrolet HHR 2LT
Mr1der wrote:stock for stock, the 18 is rated at an extra 5 hp, but it also lacks a little torque due to smaller displacement.
That would be due to the different method of rating hp that was used in the U.S. starting in 1979. L20B's were rated at 115(SAE) which changed to 100 (DIN) in 1979. Same engine. You'll notice that the hp ratings of Datsun engines all dropped in 1979. I.E.: 1978 L24E-154, 1979 L24E-120. Same engine.
jaimesix
Car: Datsun 710 , Datsun 610 , Datsun 1200 p/u
jakearmstrong wrote:i dont know i alway had v8 so i like hp how muck can you get out of the 18 or 20 if i put duals on the 18 would that help the torque
A V8engine is not a bad motor, but its gasoline consumption makes it prohibitive, specially if modified.
My 610 is getting a 5 speed gear box ( to replace the stock automatic ) . The engine was in perfect shape, so I am adding a 38DGES Weber ( later on I will add twin DCOEs) headers, and a cam.
That should make a fun to drive fast and reliable Datsun.
If I had to choose from 2 engines sitting on the floor, both in the same stage , I would go for the L20B, because it has more torque , in city driving, that torque feels great. If you have an L18 already, in that case, just keep it, modify it to suit your driving preferences, and enjoy it.
L18s rev higher , that is the plus, but unless I was looking for a high RPM race car, I take torque over RPM, specially when talking about two similar engines, RPM being not a dramatic difference.
Jaime._________________________________________________
Mr1der
Mig wrote:That would be due to the different method of rating hp that was used in the U.S. starting in 1979. L20B's were rated at 115(SAE) which changed to 100 (DIN) in 1979. Same engine. You'll notice that the hp ratings of Datsun engines all dropped in 1979. I.E.: 1978 L24E-154, 1979 L24E-120. Same engine.
cool deal.
didn't most of the makers just recently change how they rate again?
jakearmstrong
thank you
Mig
Mr1der wrote:
cool deal.
Don't know. I don't follow that sort of thing with the newer cars.
Mr1der
fair enough.
they're all plastic boxes anyway.
I miss cars with a soul to them....Toyota hasn't had one in a long time.
Return to “Datsun Chat”
