l.s.d. question
Hellion240sx
Car: 1992 240sx se
someone told me today that a 93-96 infinity g20 (t?) lsd will fit on the 240s. And also he told me that it would knock off a second off of the 1/4 time.???? someone please clear this up. what year 240 will it fit, if it even does????thanks
Nismo_Freak
Car: 89 Nissan 240SX
No... one car is FWD the other is RWD, the LSD will knock off a few tenths at the most.
J30 LSD will fit however.
Hellion240sx
Car: 1992 240sx se
cool thank you very much. so is there any particular j30 i have to find? or just any j30 will do? cuas eif anything i will find out how much for a used one depending on the year. would i be able to do it myself with someone who has some knowledge of what to do ????thanks again
Hellion240sx
Car: 1992 240sx se
oh yeah what year 240 though. i have a 92. also did any 240's 91-94 come with an lsd???
s86d
Car: autocross, backroad racing, and working on 240's
yes the hicas 240 came with a lsd and pre 95 j30 will match up and also the 300zx also matches your bolt pattern. The availability for you is much higher than it was for me. HAPPY HUNTING
Hellion240sx
Car: 1992 240sx se
hah thanx. ok now whow do i tell if its a hicas 240? cuz i know someone with a 92 240 parts car!!!
s86d
dual pwr steering lines on the pump. steering components in the rear (to turn the rear tires) and most obivious the neon construction orange viscous sticker (may require cleaning too see)
Hellion240sx
Car: 1992 240sx se
ok on what pump, steering components, where is this orange sticker? i was looking at the car yesterday, and i was like hmmm this dosnt look exactly like mine, so i decided to post on here. ok try to tell me in more details. and thanks again s86d for the info.
s86d
oops pwr steering pump the viscous sticker will be near the middle or upper left side of the rear cover of the diff.
Hellion240sx
Car: 1992 240sx se
see i dont know where the diff is im prteey sure i hve the idea. under rear between tiresd heh but thats about it. i'll have to take another look at it.
s86d
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
a Super HICAS equiped car will say "Super HICAS" in big *** letters on the side of the car.
Hellion240sx
Car: 1992 240sx se
hmmm intresting i think imma give him a call tomm. thanks guysi dont recall seeing a word about hicas on the outside of the car is their any sign on the inside?
Cyberkreig
Car: 1993 Nissan 240SX SR
Nismo_Freak wrote:J30 LSD will fit however.
I have yet to find anyone that will give a strait answer about what is needed for the J30, Z32 or JDM VLSD Swap.
No one seems to know what output flanges and rear half shafts need to be used.
s86d
look under your car if you have the 5 bolt (each bolt hole has it's own ear ) or 6 bolt ( two holes per ear ) z32 is 5 bolt (they never changed) j30 is 5 bolt pre-95. 95 and newer its 6. Same for 240 equipped lsd's
Cyberkreig
Ah thank you for that info! I have the 3-tab 6-bolt... that means i could have LSD! or a lsd swap just got a ton easier.
s86d
possibly but if you dont. You are limited to what you can buy. the newer diffs. (6 bolt) are harder and more expensive to find. To make things worse I confirmed my fears that nissan doesnt make lsd output shafts anymore (me and one other guy waited almost 2 months when finally they deliver the bad news w/refund) but if you can save you should be able to find one under 400
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
s86d wrote:look under your car if you have the 5 bolt (each bolt hole has it's own ear ) or 6 bolt ( two holes per ear ) z32 is 5 bolt (they never changed) j30 is 5 bolt pre-95. 95 and newer its 6. Same for 240 equipped lsd's
ok, so the pre 95 j30, the N/A z32 and s14 all have interchangeable diffs?i ask because the KAAZ website doesnt site an application for the j30, but the N/A z32 and s14 use the same diff part number...
rco8786
s86d wrote:yes the hicas 240 came with a lsd and pre 95 j30 will match up and also the 300zx also matches your bolt pattern. The availability for you is much higher than it was for me. HAPPY HUNTING
NO. 300zx diffs do not match the bolt pattern, you will need either j30 axles or jdm s13 axles. The j30 has a final gearing a 3.9 and the 300zx and 240 both have final gears of 4.08(some older jdm s13's had 4.3). so the j30 will give you lower accel and higher topend. I'd go with the Z32 diff and j30 axles.
RobDET
Car: Cars
Marco Vargas has 180sx VLSD's. I got mine with the Pumpkin and the CV joints for 400 bucks.
http://www.sr20store.com
The one i got from him is 5 bolt and VERY tight still.
cornkillerS14
rco8786 wrote:NO. 300zx diffs do not match the bolt pattern, you will need either j30 axles or jdm s13 axles. The j30 has a final gearing a 3.9 and the 300zx and 240 both have final gears of 4.08(some older jdm s13's had 4.3). so the j30 will give you lower accel and higher topend. I'd go with the Z32 diff and j30 axles.
JDM S13 axle is different from USDM? how are they different? Are you saying pre95 J30 are using same axle as S13? So can you match up a pre95 J30 VLSD with a S13axle and install them on a S14? or Can you just switch the OEM open differential cover with the pre95 and install it on S13? (also buy longer differential carrier bolts according to another guy)
thanks
Hellion240sx
Car: 1992 240sx se
any body got the phantom grip lsd????Part# 908-Gold, fits 89-98 Nissan 240SX R180, R200and what is difference between the clutch, disc, and viscous lsd?thanks
creophus
Car: 240SX SE & 200SX
You're gonna have to do some searching about open and limited slip diffs man. I've been researching and there's plenty of good info out there.
Hellion240sx
Car: 1992 240sx se
i was asking b/c i can get one for $300 shipped :) shuold i get it?
s86d
thats how much mine cost shipped been running great for quite some time. I did have it inspected before i installed it.
Hellion240sx
Car: 1992 240sx se
what d you mean inspected? you got the same as the model # i put up there? also what do you check for when inspecting it? and it just bolts on??? i dont have a lsd tho? but they said you dopnt need one... aaahhh im so confused. well i'll be on later have to go to work. sigh uugghhh!!peace
RobDET
Car: Cars
Marco said he shipped me a 180sx vlsd with 180 axels. They were different than my stock diff. You can believe that or not but it's true :D
the 180's had 5 boltsthe open diff had 6
rco8786
Cyberkreig wrote:I have yet to find anyone that will give a strait answer about what is needed for the J30, Z32 or JDM VLSD Swap.
JDM S13 Diff - requires 5-bolt axlesZ32 diff(NA only) - requires 5-bolt axles and swapping of cover plates.J30 - 3.9 final gear. 95+ will work, pre 95 needs 5-bolt axles.(never acually done this one, I think longer front bolts are needed)S14 - swapping of cover plates, longer front mounting bolts(or do some "modifications" to the stock bolts)S13 - bolts straight in
*These pertain to S13's only*
