l.s.d. internal swap question/i did search,please help.
s13lawnornament
Car: 93' 240sx coupe
Ok so i just got done swaping the internals from a j30 diff into my 240's housingand when I put the output shafts in the long one sticks out from the housing about an 1/8th inch or so and it is in the diff as far as it will go. why is it like this,and will it affect anything when i put it in the car?your help and input is appriciated. if i am online you can IM me my info is in my profile. THANKS. i can't wait to get out there and do a little
Kraelic
Car: 89 240sx
The output shafts from the stock open differential are longer than those used with a VLSD. Use the J30 differential's output shafts.
Check out http://www.ka24development.com/vlsd.html near the bottom, the section covering swapping the guts.
tintingkc
Car: G35 Sedan
Its just cause the difference in the housing. Its nothing to worry about.
s13lawnornament
Thanks for your help,i just measured it flange to flange and it is the same. It just looks weird. Thanks again.
