L-16 swap
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
NL320Nick
Anybody installed a L-16 in a NL320? I bought a 64 with no motor I would like to take the L-16 out of my 72 pickup and insall it in my 320 anyone know if it is possible and what is involved.
Thanks
Nick
71-521
I know it has been discussed, but cannot remember where that was...maybe it was garry on the yahoo forums as he has 2 and one is getting a v8
Pac. coast Datsun
[font="georgia"]Well any motor swap is possible. In your case youd probably have to make new motor mounts to mate to the L series ones along with a new transmission mount as well. The wiring shouldnt be too hard, Datsun harness's are very basic. A new driveshaft would probably have to be made too because the L series transmission is longer than the one used in the NL's.
[/font]
NL320Nick
I think I am going to change my plans, I dont want to do fabrication I want a bolt in installation. The truck has the original trans w/shifter on the column. It is my understanding that the original engine was an E1, I also beleive that a J13 or J15 will bolt in is this correct?
Thanks
Nick
IMH
A J13/15/16 or even J18 (if you could find one) will bolt in as long as you use the E1 motor mounts.   If you want to retain the column shift trans, you'll need to use the E1 flywheel, mounting plate, starter, etc.  I presently have a J16 in my 320 but I have a later model 5 speed.  I did have a J15 with the stock column shift in it before I did the present conversion.
NL320Nick
Has any used a J15 forklift motor? I thought I had read somewhere someone had. Remanufactured Forklift J15 are available does anyone know what is required or if it possible to use one?
Thanks
Nick
IMH
From what I understand a J15 forlift motor is the same as any other J15.  You would need to use the mounting components from your E1 to install it in your 320.
Jefe De Jefes
Bump!
So has anybody done this swap ?  I plan on putting the l16 in mine but it looks like it's going to be close. Especially with the 521 radiator. Also , the dual su's on the engine look like they might hit the steering shaft.
IMH
The dual SUs would be a problem.  I was going to the put the dual MG SUs on my 320 but ran into the same problem and ended up using the single Weber 40DCOE.
Jefe De Jefes
I figured. Time to rebuild another weber.
zenndog
Car: 1964 L320
Does anyone know where to get a rebuilt J15 motor? - have contacted a couple forklift companies but they never call back!
Jefe/nick- do yo want to sell your L16 if you don't use it? I am buying a 510 wagon less motor and I want to put an L16 in it.PM me if you are interested. I am in sylmar CA
Return to “Datsun 320”
