KYB Strut still knocking!!! HELP
SOUTHSHOREQX4
Car: 2002 QX4
I had a set of the KYB GR2 struts in stalled little over 2 months ago. My mechanic said that there will be some knocking on the front struts because they were new. The left front stunt is normal no noise. The right front however still knocks like crazy under 40 M.P.H. I t also started to squeak on the highway at one point but now that noise went away. It sounds like something is seriously loose but the performance hasn't changed at at. Anybody had this problem before???? Maybe the Nuts are not torqued enough....if so does anyone know what the torque specs are for the strut mounts and the strut itself?? Thanks
WPGQX4
Car: 1998 Qx4
Did you replace the strut bearings as well? Most knocking isn't your strut, it's the bearing.
SOUTHSHOREQX4
Car: 2002 QX4
Yes they replaced both....the left side was making noise as well in the beginning but i guess it broke in and now is fine....I'm thinking maybe something got loose on the right side???The truck is not sagging or anything like that just a loud clunking/knocking that i can sometime feel of the gas pedal if the bump is big enough
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
I'm not aware of any knocking that should occur with new struts. Sounds kind of weird to me.
fleurys
Car: 2001 Pathfinder , Locked and loaded !
If you do not have the ac coils, then it should not knock. If they changed the strut bearings and installed the ones from KYB, then they might have failed you already. Do not wait and have your strut checked and dismantled. Have a look at the strut bearing... if that's not the problem, then your strut nut might have started to strip, or your 3 bolts holding the strut in the tower are either slack or started to strip... in any case, you need to have this checked before you get stuck somewhere on the road with a ripped strut...
If you do not know if OEM Nissan strut bearing were installed, I would go buy these right away and have the other changed while they are dismantled...
Read more here : http://npora.ipbhost.com/index.php?showtopic=20421
SOUTHSHOREQX4
Car: 2002 QX4
I read on the forum about the strut bearings. I went to the dealer and bought them and had him put them in instead of the ones that came with the struts from KYB. I also changed the springs but used OME all around. Something has got to be up with it cause the left strut works fine. Theres no noise from it at all...Is it possible the strut itself is defective???
fleurys
anything's possible... it needs to come off for a good check
ARKQX33V6
Sounds like the shock within the strut has busted and no dampening is happening that is why you hear banging. Tear them out check them and if no good replace them...under warranty.
SOUTHSHOREQX4
Car: 2002 QX4
Ended up being the strut mounts...I changed out both and its so smooth over any bumps..... Not one rattle anywhere...feels like a brand new truck Thx for the help guys
new2infinitiqx4
Car: 1999 infiniti QX4
what about the rears.. the old shocks didnt make noise but the truck sat real low.. so i replaced them with kyb gas a justs and i hears knocking here and there .. sounds like someones tapping the wheel wells
