The new struts are awesome. The ride is nice and firm. The car feels like a 7 series Bimmer.
The question I have is this:
There is a rattle / clinking sound from the front when going over rough road.
Where / what is causing the noise?
Here is my thoughts - the front SR Special inserts were not the same as the OEM insert struts. The OEM has a shaft bushings in the cap where as the SR Special has the bushing in the strut insert and the cap did not have anything. Also, when I screwed on the SR Special Cap, the assembly was loose, so I added a smaller diameter O ring inside which which eliminated the play. But I am sure if there is still a vertical and/or lateral play.
My SR Special box had a hole, so I am wondering if there is any parts that got lost.
Also, the original strut insert look different from other OEM inserts. Are the 98 Touring inserts different from standard inserts?
So - any help would be appreciated it.
Thanks.
