Gary@Tirerack wrote:Sort of. All Konis are adjustable. The difference is the Yellow can be adjusted without being removed from the vehicle, whereas the standard Koni's need to be removed to adjust them. The GR2 is not adjustable at all.
I may be mistaken here, but I believe only the front shocks are adjustable *on the car* with the Koni Sports. The rear shocks must be removed from the vehicle to be adjusted. Also, you will need to modify your OE strut housing on the fronts, as the Koni Sports are inserts in the front.
The Tokico Blue shocks are *not* adjustable.
There really aren't any short stroke shocks readily available in the US, and matching aftermarket dampers to aftermarket springs can be tricky stuff...as Q45tech pointed out, the life of suspension components and ride quality may suffer.
So, unless you can find some short stroke shocks on Ebay (buying big ticket items on Ebay makes me nervous...too many con men out there) your best bet is the KYB AGX, IMO. Someone here at NICO had some KYB Buzz Specs (short stroke) and wasn't really happy with the ride quality, as I recall...can't remember the springs that he was using.
Anyway, short answer...in my opinion the AGX are your best bet. Good luck.
Edit: Turboweege, Q45tech posted some really interesting stuff. I highly suggest you read through it if you haven't already.
