festino wrote:Did you use the bumpstops from the stock setup or are you using the agx boots? The agx boots that I had slipped down over the stopper on the pistonrod and that caused a rattling sound because there was an inch or so of play in the spring before the shocks would start dampening. However I doubt this is your case because it was very unstable to drive around in. The only reason i mention this is because before I figured out what was wrong, I thought of taking off the cap to solve the problem as well.
turns out this was exactly my problem..before I came on NICO this morning I took off the assembly on both rear sides and looked at them again. I used the KYB dust boots and when I put them on at first, they wouldn't go down over the little "nub" or "stopper" on the strut rod. I figured this was fine and didn't install the stock bumpstop and that other metal plate. Well, when the weight of the car came down on the strut, the top of the dust boot was pushed over that nub, thus making this gap you are talking about. I made sure the boot was on the lower side of the stopper, placed the plate and bumpstop back on, then the rest of the stuff. That was the problem, there was no noise during my road test. I had it set on 3 and 6 and watching my dad drive it there was like ZERO body roll, it was great. I'm real happy with them. Then again, I went from blown struts to a harder setting on the AGXs..live and let learn, thanks for everyone's help. now I'm DONE modding this car for awhile, time to save the $$.
